Group Policies, traffic priority setting not available
francktls
Dear Community,
Do you know why sometimes it's possible to set a priority (high, Normal & Low) in a traffic shaping rule and sometimes this menu doesn't exists ? See  below the difference between 2 different dashboards, same advanced license.
Maybe I missed something easy. Many thanks for your help.
Franck.Group policies configuration - Meraki Dashboard - Google Chrome_2.jpg
3 REPLIES 3
NolanHerring
Re: Group Policies, traffic priority setting not available
Are these from the same network?
The one on the right seems to be on a network with an MX and the one on the left seems to be from one without an MX appliance. However I just tested and I have two networks, one with an MX and the other with just access points.
I wasn't able to replicate your issue myself, which is odd. Maybe the firmware versions of the network affect that feature?
The only place I could find 'priority' was under the SD-WAN & Traffic Shaping for the MX, if I created a custom rule there.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
I think @NolanHerring  is onto it.  Your can only have this setting when there is an MX in the network.
francktls
Sorry guys, both networks have MXes and both with advanced license...
