VLANs
VLANs
VLANs would help maintain PCI compliance in small business where they have multiple devices plugged into the firewall or switch along with a card reader.
For this use case, since card readers do not typically support VLANs, the ports on the firewall or switch should be able to add and remove the tag as necessary.   Also this use case would benefit by blocking all traffic between VLANs.
Accepted Solutions
Meraki Go Team
Re: VLANs
@DHAnderson & @Roska - VLAN support has now been released in the latest version of the Meraki Go mobile app.
James Wilson
Meraki Go | Americas Theater
4 REPLIES 4
Re: VLANs
I agree, +1 on this.
Meraki Go Team
Re: VLANs
James Wilson
Re: VLANs
 When I tried to save the VLan, I got an error saying that VLans were not supported, so I couldn't save it.
Re: VLANs
I tried creating a VLAN again today, and it worked!
I'm not sure if it was a firmware update (no way to see firmware version), or a reboot of the access point (I had to move it to another location).
- Dave
