Setting Up a Captive Portal
Thomas_Droese
it is possible to setup a captive portal with Meraki GO? I need to setup a portal and look for a solution.
Thanx
3 REPLIES 3
hidden0
Meraki Go Team
Good day,
It depends on how extensive a captive portal you need. Here is what we have available today:
https://documentation.meraki.com/Go/Meraki_Go_-_Landing_Pages
These landing pages can be configured within the app, or you can point to an external captive portal of your choice. You should have a 30 day return policy available if you wanted to give it a test run.
Let us know what you think about this solution and if it covers your needs adequately.
That is a great document I couldn't find using a normal search and it almost looks like it will work. Both of the providers linked below require Radius authentication that I do not see mentioned on the link you provided. Can Meraki Go work with either of these providers? Even on the Meraki Enterprise side a request has to be put in to support Radius Accounting so I'm hoping it could be done.
Thanks!
https://help.stampede.ai/en/articles/4641077-setting-up-your-cisco-meraki-integration
https://www.aislelabs.com/wp-content/uploads/2019/03/Meraki-Aislelabs-Integration-Guide.pdf
Lee
Meraki Go Team
Meraki Go Team
Meraki Go does not support Radius authentication, so may not work with Stampede or Aisle Labs. Splash Access and Purple Wi-Fi are two solutions that have been used successfully with Meraki Go.
Lee
