Real mac address
Marc_Potter
Real mac address
Hello sir/ madam,
I was checking a solution (products or software ) has the following specifications:
1) Capture the REAL MAC-Addresses of mobiles
2) Be able to capture all mobile brands
3) Capture the REAL MAC even when the WIFI is disconnected (not the randomized mac address)
4) Capture the REAL MAC even when the WIFI is turned off
Hope to hear from you soon.
Thank you for your help and consideration.
Best regards,
Marc Potter
1 Reply 1
BrechtSchamp
No solution will be able to do this. It's kind of the point of the MAC address randomization. Infrastructure has no control over client behavior.
