Hi guys,
We are using a MX64 to provide our clients with Client VPN on the main internet port and then on the other internet port we are providing a guest network.
This works fine at the customer and we have it set so the internal IP address of the MX64 is set as the default gateway on the servers. Everything works internally and externally.
Recently the client has had an additional class opened at another site and the local authority who provide the connections have created a VPN connection that goes from the main site to the second site. When we have the client vpn up and running neither site are able to talk to each other. All they can do is ping the default gateway of each remote site. So site A can ping site B's default gateway and site B can ping site A's default gatway. From site B we are able to ping the MX64 internet ports IP address and thats it as soon as you guy higher we are unable to ping anything. I have been on the phone with support and they have told me nothing is being blocked on the Meraki. The MX is set up in Routed Mode. All firewall rules are off all outbound and inbound rules are all set to Allow and Any.
Any help would be great.
