LACP/LAG
NexFirmJC
LACP/LAG
Why is it that one of the best devices (MX68, 75) for small businesses don't support LACP or LAG?
Who can we send an email to to implement this, even if they increase the cost by a couple of hundred?s
5 Replies 5
RWelch
Meraki MX appliances do not run LACP or any link aggregation protocols (intentionally by design).
If you wanted to make it a request you can Give your feedback (previously Make a Wish)
This is the document that contains the information described.
https://documentation.meraki.com/SASE_and_SD-WAN/MX/Design_and_Configure/Configuration_Guides/Networ...
I'm with you on this one!  I suspect it is a limitation of the switch hardware.
ffiol
Hello, we encountered the same problem and found this workaround.
How to connect the Meraki MX to MS switches – Karstens Cyber-Fi Blog
Tested and proven to work wonderfully.
I hope this helps.
Regards.
It's not an workaround, it's the design proposed by Meraki.
