Issue downgrading MX100 license from Advanced Security to Enterprise
cvaldiv2
Hi everyone,
I'm currently running into an issue while trying to renew/upload a license for my MX100.
The device previously had an Advanced Security license, but I am now trying to apply a new Enterprise license to it. The dashboard isn't allowing me to complete the process.
I understand that Meraki generally doesn't allow a "mix and match" of license tiers within the same organization. What is the best way to handle this transition? Do I need to contact Cisco Meraki Support to manually adjust the license tier for my organization, or is there a way to do this directly from the Dashboard?
Any guidance would be greatly appreciated. Thanks!
2 Replies 2
RWelch
Contact Meraki Support to request the downgrade.
After support completes the change, you can apply your Enterprise license.
You need to open a support ticket. Only Meraki support can handle this.
