2 cellular connections
nowisuwi
I have an MX67C in the field now with Verizon service. I want to plug in an aircard via the USB port with AT&T service. Can this work on the MX67C?
Can i remove the Verizon sim that is inside the MX67C and use only the aircard on AT&T service for connectivity on the device?
The Top 50 Free Porn Sites. This is our list of the top bestandfree sites. A lot of effort has gone into making this high quality list for you. Freeporn.ooo, PornVideos.fans, PornMovies.site
2 REPLIES 2
the MX will prefer an external USB modem to the internal modem, if available
You can only use supported usb sticks on the port https://documentation.meraki.com/MX/Cellular/3G%2F%2F4G_Cellular_Failover_with_USB_Modems#Compatible...
SoCalRacer
Short answer is yes. Check the documentation below. Also confirms USB will take precedence. Also note LTE is only supported in fail-over, not primary.
https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/MX67_and_MX68_Datasheet
