HI all
I try to test add VPN profile using SM to laptop windows 10. The vpn profile already pull to my laptop but when I try to create vpn connect my laptop get error "The L2TP connection attempt failed"!
I try the same with MacBook every think working smoothly.
There are anyone get the same problem ?
Thanks All
