App Utilization
k12Engineer
App Utilization
Does anyone know if Meraki MDM has the ability to track App Utilization on iPads? We are looking for a way to track what apps are actually being used.
2 REPLIES 2
SoCalRacer
Under System Manager>Monitor>Summary
There is a Top Unmanaged App section. Not sure if that is the info you are looking for. I think it will only track installs not actual app usage time.
vassallon
@k12Engineer Are you trying to tell which Apps are actually being used on the iPad?
I think the closest I've seen to anything like that comes from the Apple Schoolwork app.
I have not seen anything in Meraki that monitors actual app usage and I would suspect that Apple would be highly protective of this data based on their stance on security and privacy.
