SM seatCount
MohammadFakrulA
SM seatCount
Hi All,
What is the implication or usages of SM Seat count? For example, if I have 100 SM licenses and assign 10 seat counts to network ABC; does it mean I can't have more than 10 "managed" SM devices under that network?  What will happen if "seatCount" is null?
Getting the following payload if I call "https://api.meraki.com/api/v1//organizations/:organizationId/licenses" API for PDL license:
    "id": "6111111111111111111113",
    "licenseType": "SM",
    "licenseKey": null,
    "orderNumber": null,
    "deviceSerial": "",
    "networkId": "L_6111111111111111111113",
    "state": "active",
    "seatCount": 20,
    "durationInDays": null,
    "totalDurationInDays": null,
    "permanentlyQueuedLicenses": [],
    "claimDate": "2020-05-13T06:46:18Z",
    "activationDate": "2020-06-25T13:10:12Z",
    "expirationDate": "2021-06-25T13:10:12Z"
2 REPLIES 2
You can't assign a number of licences to a specific Systems Manager network.
The sum of all Systems Manager licences across all the networks can not exceed the quantity purchased.
Thanks, @PhilipDAth. Make sense. But a bit confused with the following API:
https://developer.cisco.com/meraki/api-v1/#!assign-organization-licenses-seats
Description: Assign SM seats to a network. This will increase the managed SM device limit of the network
What would be the use case for the API?
Regrads.
