What devices can cloud control add?
jieke
I wonder if adding cloud control is a must to use Cisco equipment?
Is it possible to add routers and switches?
2 Replies 2
RomanMD
To be honest, I did not get the question but if you refer to cloud control as "What Cisco devices can you add in Meraki dashboard for monitoring" then they clearly said - Catalyst 9k switches - 9200, 9300 and 9500.
EJN
Can you be more specific on your question? Meraki devices (division of Cisco) are exclusively cloud controlled. Must use the cloud (dashboard) and musts have/renew a license every so many years. No license will result in the equipment not working. Is this your question or are you asking regarding other Cisco products (non-Meraki)?
Esteban J Nunez
School and Church
K-12 Education
