M45 reporting too high other AP transmit power
PawelG
I know that there is a bug causing MR45 (and I guess MR55's) to report completely insane values of other and rogue AP transmit power (something around 160 dBm). This causes to strange values in Air Marshal reports and RF Spectrum - almost all neighbors are shown as -40 dB.
Anyone know if there is any workaround or we just have to wait till it is fixed in firmware?
Br, Pawel.
1 REPLY 1
TheITWay
At the moment, I do not think that there is a workaround for that issue.
The good part about Meraki Support is that you can create a case and if there is a bug identified, they can attach your case and provide an update when the bug is fixed. I would recommend you do that and you will definitely know when the problem you are facing is fixed.
