Guest WLAN Firewall Rules
big-net
Hallo,
we've setup a new meraki envirenment with a MX250, 2 MR42 and 2 MR52.
We've setup an internal wlan which works perfect.
We also have enabled a guest wlan with NAT mode.
The clients in the guest wlan only get access to the internet.
But it does not work.
How must the firewall rules be setup?
Under the layer 3 firewall rules?
Should there be set any rules under the firewall section for the MX250?
Any help would be appreciated.
thanks, Oliver
1 Reply 1
What specifically does not work?
Make sure "Deny Local LAN" is enabled.
https://documentation.meraki.com/MR/Firewall_and_Traffic_Shaping/'Deny_Local_LAN'_settings_in_Cisco_...
