MS14.33 firmware now stable release
The 14.33 firmware has now replaced 14.32 as the stable MS release with upgrades now being pushed out automatically.
6 Replies 6
mcvosi
Why is Meraki forcing this update?
@mcvosi they are recommending it as it contains important fixes, however if the fixes don't affect you then you can simply cancel the scheduled upgrade from that page in the dashboard.
mcvosi
Mine just says. Nowhere do I see cancel; just upgrade now, re-schedule or use the current schedule.
Switch firmware
New firmware is available for this network. The upgrade is scheduled for Monday, March 7, 2022 at 03:30 CST
@mcvosi Go to Organzation | Firmware Upgrades | Scheduled changes and you should have a Cancel option.
mcvosi
Got it.
Thx!
Keep in mind numerous older versions are listed as critical and not supported.
