Upgraded our MX68 estates to 15.43 yesterday all sites reported network issues. Rolled the upgrade back and stability was restored. Unforunately, I was not informed until after the downgrade took place.
We have 12 remote networks configured for AutoVPN with a central MX400 which was also upgraded to 15.43. The the dashboard indicated a problem the autovpn feature having stability issues. VPN's were constantly going down. Stopped once we rolled back to 14.53
Anyone else experienced issues with 15.43
I experienced that also.
Just MX68? Or other gear too?
Other gear mx64 and mx65w I had the mx250 do it too
MX68W and MX400 was impacted. The 400 acting as a hub to the MX68 spokes.
Hey folks,
If you haven't already, I'd ask to raise a case with the Support Team. If 15.43 is causing this type of problems, we surely want to gather enough data to create a report for the developers so that it doesn't impact subsequent releases.
For VPNs in particular it's always good to grab packet captures on the Internet interfaces of the MX(s) and attach them to the cases along with timestamps so we can check logs in the backend.
Would also be interesting to see if the issues are with MXs that are directly public facing or behind NAT.
Many thanks!
Giac
