DEP is down ?
MDT
DEP is down ?
Hello everyone,
since several weeks, DEP doesn't work. We have setup all correctly, the status of Macbook change pending/assign/pushed but when we turn on the mac, at the login and password screen, we enter the login and password owner meraki and it doesn't work. Nothing happen. Any idea ?
We have open 5 tickets to Meraki Support but we don't receive a good feeback. I try to call yesterday during 35 minutes, nobody answer.
Last chance is here with the community
Thank you in advance for your help and I wish you a very great day.
3 REPLIES 3
Shany
Sometimes I had an experience that was not connected to DEP.
It will be fixed after some time, but for quick resolution, renewing DEP token with ABM/ASM will solve the problem immediately.
https://documentation.meraki.com/SM/Device_Enrollment/Apple_Device_Enrollment_Program_(DEP)
If token is renewed normally, there will be no effect on existing enrollment devices.
What is the status of your Apple push notification certifiate?
www.btr.net.nz
@BlakeRichardson
the status is up to date
