Insight support applications
Hi is there a published list of the applications Insight can provide viability into? Does Insight c only looks at Web based –HTTP/S based flows?
3 REPLIES 3
Re: Insight support applications
I don't know of a list... Not outside of the Insight configuration page...
Yes, it's only HTTP and HTTPS.
I was going to do some screenshots for you - but there are two any.  Currently 200 web applications show up as being supported.
You can only add http and https apps.  It is primary designed to support web apps, but then it also lists things like Skype, so ...
I haven't been able to find any info for you through searching either sorry. Contact support or if insight is something your looking at jump in on a webinar.
