Bridging a VLAN to a stand alone AP
HEJ
I have a telescope that acts like an access point, allowing people nearby to connect and control the device.   I'd like to be able to bridge a VLAN on my Meraki network to that telescope's SSID so that I can extend the range of that further into my home.
I've tried researching through the documentation online, but am not able to find a way to do this.
I have MR52 APs and an MS225 switch.
Thanks in advance
5 REPLIES 5
Greenberet
 You will need a MX for that.
Basically the AP will create a VPN connection to the MX and the mx will forward all packets to the vlan.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/SSID_Tunneling_and_Layer_3_Roamin...
Only Merai APs can do that.  The AP built into the MR wont have that capabillity.
Does the Telescope have an Ethernet port?
Another option - can the telescope act as a wireless client and join your existing wireless network? This would make everything easy.
HEJ
Doesn't look like it.  Thanks for the replies though!
