Hi Everyone!
Pre-staging switch ports for wireless deployment might be time consuming and often it's a game of guessing.
How many APs will be plugged in a specific switch?
How many time will I check or change the configuration to make sure that all the ports and only the ports were an AP is connected are properly configured?
With SecureConnect you can leave those questions in the past!
SecureConnect automates the process of securely provisioning Meraki MR Access Points when directly connected to switch-ports on Meraki MS Switches, without the requirement of a per-port configuration on the switch.
Let's see SecureConnect in action.
Video courtesy of #merakiminute
🗒Read more about SecureConnect
ℹ️ Check supported models and minimum FW versions
The Meraki ECMS exam is now live! Test your knowledge of Meraki and become an official Cisco Meraki Solutions Specialist. More info on the ECMS exam found
here.For information regarding all of Meraki's training offerings, be sure to check out the
Meraki Learning Hub.
