MX Local Breakout Validation
padgettmv
I've been digging through the Meraki documentation and searched the forums and couldn't find a definitive answer (or didn't interpret one from what I read).
I'm looking for a way to validate the routing direction for traffic. If there is a specific screen that can be used to confirm configured breakout traffic is indeed routing locally versus over the VPN to the Hub.
I know VPN Status shows traffic that flows over the VPN, but the destination only reflects the destination IP, not the App ID (with smart breakout). Makes it difficult to confirm for sure by evaluating what is or is not there.
Does something like that exist and maybe I just overlooked it?
1 Reply 1
Mloraditch
I can't think of anyway to do this except via packet captures. Support may have deeper access to the full routing table on the MX, whether they can share any of the proof you need, I'm not sure.
