MS225 moving between network
there is a way to don't lost a configuration when i move a switch from a network to other?
Thanks,
Simona
2 REPLIES 2
Re: MS225 moving between network
The config is based on the Meraki Dashboard network it is in.  If you move it to a different Meraki Dashboard network then it will use the configuration from that network.
There is no way to copy the config from one switch to another switch when they are in different Meraki Dashboard networks.
Unless the new network doesn't already exist and you can try cloning the existing network.  But I'm not 100% positive on this.  Either way I'd screenshot or document your current config before moving it.
