MX64 Client VPN Cloud Auth Works - Radius Auth Fails with IPsec-SA expiration
Coupe2112
I have configured a Client VPN on this MX device. When using Meraki Cloud authentication it works without issue. When I enable radius authentication it fails.
I have performed a packet capture on the radius server and see successful authentication requests validating that radius is functioning correctly. This is failing for both an Android client (ver. 9 build PPR2.181005.003) and Windows10 Enterprise (ver. 1709 build 16299.611)
Below are log entries. It looks to me like it's simply timing out.
Oct 29 08:28:15 Non-Meraki / Client VPN negotiation msg: ISAKMP-SA established x.x.x.x[4500]-y.y.y.y[4500] spi:f7576fb374b0f3a5:75cfbc1463066f9b
Oct 29 08:28:16 Non-Meraki / Client VPN negotiation msg: IPsec-SA established: ESP/Transport x.x.x.x[4500]->y.y.y.y[4500] spi=68336299(0x412baab)
Oct 29 08:28:16 Non-Meraki / Client VPN negotiation msg: IPsec-SA established: ESP/Transport x.x.x.x[4500]->y.y.y.y[4500] spi=125451427(0x77a3ca3)
Oct 29 08:28:21 Non-Meraki / Client VPN negotiation msg: purged IPsec-SA proto_id=ESP spi=125451427.
Oct 29 08:28:21 Non-Meraki / Client VPN negotiation msg: ISAKMP-SA expired x.x.x.x[4500]-y.y.y.y[4500] spi:f7576fb374b0f3a5:75cfbc1463066f9b
Oct 29 08:28:21 Non-Meraki / Client VPN negotiation msg: ISAKMP-SA deleted x.x.x.x[4500]-y.y.y.y[4500] spi:f7576fb374b0f3a5:75cfbc1463066f9b
My confusion is why the different behavior going from cloud auth to radius when I can confirm that radius is working.
Has anyone seen this before?  Any suggestions?
2 REPLIES 2
AdamB
hey @Coupe2112,
Those log entries indicating the tunnel is being torn down could be due to a failed RADIUS authentication attempt. In your packet capture did you see the server sending back an access-accept message? You could also run a capture on the LAN interface of the MX during the authentication process and make sure that the access-accept message is making it back to the MX.
Thanks.  If you read through my conversation with PhillipDAth you'll see that I did just that both on the radius server and the MX.  I was getting ACCEPT packets and they were being seen by the MX.  In the end, radius *was* failing between the client (MX) and server (M$ NPS) because the PSK was too complex and I needed to remove non-alphanumeric characters.
It doesn't explain why I was getting the ACCEPT which was seen by the MX and was failing between the LAN interface and the Client VPN.
