Meraki MX 105 High Availability not working
Shyam1
Hi ,
We have two links one with /30 subnet mask , other with /19 subnet mask ( static IPs configured on Standalone Firewall WAN Interface )
When we tried to configure warm spare between 2 MX105-HW , we faced the following issue.
IP Conflict : Uplink IP address is the same on other device.
After configuring warm spare , both the primary and secondary were in Current Master state.
Kindly help me with how to proceed further, do we need to ask ISP for 2 separate public IP per ISP or with the same /30 & /19 subnet HA can be configured ( note : in /19 ISP - only one IP is able to reach public internet )
Yes you need 2 or 3 ip's from each isp.
"Ensure that both MXs have their own uplink IP address for dashboard connectivity as described in the Uplink IP Configuration section.
If a virtual IP is being used, an additional IP address is needed, and all three IPs must be in the same subnet."
https://documentation.meraki.com/SASE_and_SD-WAN/MX/Design_and_Configure/Deployment_Guides/MX_Warm_S...
Shyam1
Thank you for the response . I will check on the same and get back to you.
Can you please help me with the list of pre-requisites for setting up Warm Spare in 2 nos. of MX105 as Active Passive
DarrenOC
As already mentioned by @ww .  You need a /29 from your ISP for HA. One IP per MX and a 3rd as the VIP
Shyam1
Can we setup HA on One ISP link with 2 separate public IP , and other Broadband link with /30 and can we achieve ISP failover in that scenario . Please share me the cable connectivity and configuration steps.
