Converting MPLS Transport Environment to Full WWW Environment
Rifa
We have a branch enviontment as follows:
A. 50 Branches:
Connected with single MPLS transport (256 Kbps) for corporate communication.
DIA with separate ADSL internet connection. (only for public internet, unsecured and exposed)
B. 150 Branches:
No internet.
Is it feasible to convert this environment as follows with MX and Auto VPN/SD-WAN solution?
AX. 50 Branches:
Connected with single internet transport for corporate communication.
DIA with separate internet connection. (only for internet, secured and filtered)
BX. 150 Branches:
Strictly internet access fully blocked.
Looking for your suggestions.
3 REPLIES 3
WilliamQin
Re: Converting MPLS Transport Environment to Full WWW Environment
Hi Rifa.
About Meraki SD-WAN is based Multiple WAN links(DIA), if you have not two WAN Links(DIA), only one WAN link(DIA), I think you cannot make SD-WAN,  meraki SD-WAN  and MPLS link have not relation,The SD-WAN only can make two WAN (DIA) links, you cannot chooes MPLS link as you sd-wan, The SD-WAN based two wan (DIA), if you have two wan, you can configure Auto vpn base two wan(DIA)links Line real-time quality configure SD-WAN, you also can make base application and traffic type configure sd-wan,SD-WAN There are some parameters,for instance, link delay,Jitter, packet loss rate,etc... According to the defined parameters, select the appropriate line to send packets.
i hope usefull fo you .
Yes.  If you are keeping the MPLS, you will need to use the AutoVPN over MPLS design.  This document discusses this scenario:
https://documentation.meraki.com/MX-Z/Site-to-site_VPN/Configuring_Site-to-site_VPN_over_MPLS
Otherwise it will just be a simple AutoVPN over Internet setup.  For the sites you don't want to have any Internet access you can choose to make them use a "full tunnel" which sends all traffic back to the "hub" site.
https://documentation.meraki.com/MX-Z/Site-to-site_VPN/Site-to-site_VPN_Settings#Hub_Type
WANKiller
All is feasible and I recommend SD-WAN deployments.  As Phillip has stated, Auto-VPN has to be used over MPLS connections feeding back to a HUB MX for MPLS connected sites.  Auto-VPN with DIA can be achieved for Internet-only sites.
You can then achieve a mixture of HUB/Spoke and Full mesh topology if required.
DIA FTW!
