Rack Mount MX64 - an old question now with a solution
GaryShainberg
All,
Over the many years I have been "Meraki-fied" I have ofter looked for and see people ask for a way to rack mount MX64's - look no more.
https://eu.rackmount.it/webshop/rm-ci-t4.html?gclid=Cj0KCQiAhs79BRD0ARIsAC6XpaVKHJ-58t8sFOPeFCJQDwee...
I have just had one delivered and other than having to remove the rubber feet, its an awesome solution, not cheap but does the job.
Hope this helps reduce the stress for someone 🙂
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
1 REPLY 1
I can highly recommend these.  We use them with our clients.  We use them for all the desktop MX products.
We actually import them in bulk into New Zealand and Australia now to get the freight cost down.
