Updates in Systems Manager - Command Line Request and macOS Firewall
Melissa
Meraki Alumni (Retired)
Hi all!
There are a few updates in dashboard I wanted to make you aware of.
First off - we recently pushed a new Configuration Setting for enabling the macOS Firewall. You'll find it under Settings>macOS Firewall. You can also set rules to Allow or Block specific apps, Block all Incoming Connections, and Enable Stealth mode.
Secondly, all Command Line requests (completed either through the Systems Manager>Command Line page or from an individual client device page) are logged in the Events Log under Network Wide> Event Log
More to come soon!
1 REPLY 1
BlakeRichardson
Yay thank you!!!
Any chance of a setting that blocks users enabling Filevault?
www.btr.net.nz
