Systems Manager
KGuy
Systems Manager
We are a small school but cant get SM to setup the initial and apply OS updates to MacBooks like we can iPads.
Any help with this would be great.
2 REPLIES 2
kYutobi
https://documentation.meraki.com/SM/Apps_and_Software/Deploying_OS_Updates_with_Systems_Manager
Systems Manager can deploy operating system updates to iOS 9+ devices which are not configured to use Single App mode and macOS 10.11+ devices on either an individual client basis or in bulk via a command on the Devices List.  The OS Update command will cause the device to download the update and will prompt the user to "Update Now" or delay the update.
MDM OS Update Commands are only available for Supervised 10.3+ iOS devices, or DEP enrolled and pushed Macs. iOS devices older than 10.3 will require DEP-supervision specifically.
Hope this helps.
This helps with OS update. Thanks
What about setting an image or having settings to apply for MacOS
