For a Meraki MX84, the typical way to connect clients over VPN is usually using the built-in client VPN (Cisco IPsec) that Meraki supports, rather than relying on the Windows 11 VPN interface alone. That https://tropical-casino.com/ client is basically part of the Meraki configuration you enable on the MX, and Windows will connect to it using standard IPsec settings — there isn’t a separate Meraki-branded VPN app like some other vendors provide.
