vMX100 transit routing in Azure
mtz4718
Hey guys, curious if anyone has demonstrated this working or not working because I cannot find a clear statement. When used in Azure, does the vMX100 support transit routing? Meaning can you route between multiple sites via the vMX100? Or is a mesh auto-vpn setup required? I question it's ability only because the Azure VPN Gateway appliances cannot do this.
I'm not 100% clear on what you are asking.
You can have a whole lot of spoke sites connecting to a vMX100 in Azure, and those spokes can talk to resources in Azure and vice versa.  On the Azure side you have to have a static routing table routing the spoke sites via the vMX100.
Thanks Philip!
I don't suppose you know if the spoke sites can reach each other via the vMX100 by hair-pinning?
Yes they can.
