The Meraki portfolio just got a little bigger! We just added new indoor and outdoor models to our latest line of cameras with new features like smart retention.
These new cameras continue to utilize AI-powered advanced analytics like attribute search, people/vehicle detection, people/vehicle counting, and heatmaps!
PRODUCT DETAILS:
✅ Varifocal lens
✅ 36-112° Field of View
✅ Up to 4K video resolution
✅ 512GB-1TB of storage
✅ [NEW] smart retention feature (up to 120 days of retention)
NEW FEATURE:
Smart retention allows you to make strategic MV camera buying decisions based on retention needs (ex. 30 days) rather than storage capacity (ex. 256 GB). This feature will bring predictable retention, simplicity, and high-resolution security to your cameras.
How does it work?
The short answer is 2 recording streams!
Meraki MV cameras simultaneously record two video streams: the event stream and the continuous stream.
Event stream
The event stream continuously records footage (you choose) either Standard (1080p/24fps), Enhanced (4MP/24fps), or Ultra (4K/15fps) quality and continues to use Smart Codec. Live footage from the event stream is always available for live streaming. Once footage is recorded in the event stream, the camera retains the footage if any motion is detected. Otherwise, the footage may be discarded after 30 minutes to make room for other motion events.
Continuous stream
The continuous stream provides coverage for spans of time when no motion is detected. The continuous stream continuously records footage at 540p/24 fps for MV13, MV13M, MV23, MV23X, MV63, MV63X, MV73, and MV73X. It records at 720p/24 fps for MV33, MV33M, MV93, MV93M, and MV93X. Footage is only discarded after it becomes older than the expected days of retention.
If you currently have the following cameras (MV13, MV13M, MV23M, MV23X, MV33, MV33M, MV63, MV63M, MV63X, MV73M, MV73X, MV93, MV93M, MV93X) and are running at least MV 6.0.2, check out smart retention. I encourage you to turn it on by navigating to a single camera > Settings > Quality and retention > Retention policy and selecting “Smart”. You will see a huge difference in your days of retention!
THE M SERIES:
Lastly, introducing MV13M, MV33M, MV63M, and MV93M, existing camera models, now in higher capacities! Get up to 60 days of retention with the MV M Series cameras.
For more information check out these links below or contact your sales representative:
