Integrating mx65 with domain controller
SK_scope
Just browsing
hello guys,
I was able to join the firewall to the domain but group policies layer 7 rules are not applying unless i disable layer 3 rules. any help with this??
3 REPLIES 3
CptnCrnch
Maybe your L3 rules simply "shadow" your L7 ones? Guess you'd be the only one that would have to do that but it'S hard to tell because only you can see the config. 🙂
Untitled.jpgthis is the only group policy, and no other rules are applied on the firewall.
I applied the policy on an existing ldap group from the domain the firewall is joined to, but the group users can still open youtube.
I tried the policy per CLIENT, it worked normally, but on domain groups it is not working
Bettencourt
As @CptnCrnch said the Layer 3 rules superspeed Layer 7 rules.
You can read all about it here: https://documentation.meraki.com/zGeneral_Administration/Cross-Platform_Content/Layer_3_and_7_Firewa...
I hope it helps 🙏.
