No way to view or update IP address for single VLAN network
Kamome
I'm writing Python script to generate restore Python script based on current Meraki networks.
During that, I got encontered numereous limitations, but one of the biggest problem is single VLAN network.
I have several networks using single VLAN configuration, especially hub MX.
For those kind of networks, I can get static route via API and generate code for recreate.
But I can't read or change MX's network and IP since it doesn't use VLAN, reate static route code returns error because next hop is not int MX's network address.
It seems there were feature request for single VLAN API endpoint, but it didn't delivered nor plans to deliver yet. Is there no endpoint for single VLAN network yet?
2 Replies 2
I haven't updated my script which does this for quite some time ... but this might give you a head start.
http://www.ifm.net.nz/cookbooks/meraki-backup.py
Perhaps only use VLANs?
Nash
Why not enable VLANs, but only have a single VLAN created? That enables you to use "List the VLANs for an MX network" to get subnet, dhcp, etc information.
It's what I've done in the recent past, such as yesterday.
