Do you guys know of anyway, using the dashboard or APIs, to get a summary of alerting devices? I just happen to stumble into one of my networks in the switch section and noticed it said. "Unable to fetch configuration. This device is unable to fetch its configuration from the Meraki cloud. Please contact Meraki Support." I called support and I guess it failed its internal NTP check and likely just needs an after-hours reboot. But this got me to thinking that I don't really have a way to proactively review any alerting devices.
Even if I go to Organization>Overview and select the 'Devices' tab it wouldn't show that device as alerting there.
Another element that would be useful to have a report or dashboard would be any ports with high CRC errors.
Any input or feedback is appreciated and kudo'd.
