removing captive portal from SSID
jmcmurchie
We recently changed the captive portal (splash screen) requirement on our guest network from click through to none.
Testing this morning the initital click through page is gone, but I still get a pop up page simply saying "Success" and have to click Done to proceed.  ANy idea how I can also remove this page?
Thanks to the group
1 REPLY 1
Wireless/SSIDs/Edit
Change Splash Page to none.
If you are still getting a prompt try factory resetting an AP to see if the issue goes away.
https://documentation.meraki.com/zGeneral_Administration/Support/Resetting_Cisco_Meraki_Devices_to_F...
If you are still getting some kind of prompt then perhaps it is not the access points.  Do you also have an MX?
