Need Documentation Support
Sathwik
I am looking any official documentation to support the below:
Usually when Meraki connects to the dashboard and downloads the config, the default initial login method (username = Serial & password blank) is disabled, only way is to reset it again to factory defaults. Its understood technically. But is there any official documentation to support this from Meraki.
Thank you.
Sathwik
1 REPLY 1
KarstenI
It is not really disabled, but overwritten with the login from the network-config:
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
