MX100 secondary LAN IPs
dbigerstaff
Good morning,
We have an MX100 at the office, all working great.
I'm wanting to create an office and guest wifi network. Am I able to assign private IPs to the unused ethernet ports on our MX100 and if so how?
I cant see where I can configure these switch ports. Do I need to enable VLANs, assign IPs to the VLAN and then assign VLANs to the switch ports?
If I have to enable VLANs would everything continue to work correctly afterwards or does the LAN configuration have to be redone using VLANs?
Thanks for your help,
DB
1 Reply 1
@dbigerstaff wrote:
Good morning,
DB
no
yes
no reconfig, maybe a small hick up.
best to read this:
https://documentation.meraki.com/MX-Z/Networks_and_Routing/Configuring_VLANs_on_the_MX_Security_Appl...
you can also put vlans:enabled  in the config without saving to see what your config wil look like.
