When I set a group policy bandwidth limit it seems to also limit the amount of traffic that is available locally as well over the wifi network. Is that true? If it is, is there a way to separate it?
So you have applied a group policy to a machine, and it is affecting the machine weather it is plugged into Wifi or Wired (which is correct by design)? What outcome would you like to achieve that is different?
Yes, I want that as well, but if they are communicating with an internal server they are only seeing 5mbit of throughput, I want to limit internet connection to 5mbit only.
Drop the WiFi users into a separate VLAN. Apply the speed limiting on that VLAN on an MX. That will limit their Internet performance while not affecting internal server access.
How about you have a limit for the group policy while use traffic shaping configuration under bandwidth then from the traffic shaping under the same group policy, you have a rule for intranet subnet and choose Ignore network per-client limit.
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
