Can't delete a network from my organisation
khalidbochajra
Just browsing
Recently, I was practicing on my Meraki demo dashboard and I created two networks (test-1 and test-2) but I didn't do much with them and I didn't make any kind of configuration. Lately, I wanted to delete them but I was surprised that only test-2 network got deleted while test-1 network shows "Internal server error". Could it be because it’s just a demo? Or should I wait and give it a try later?
Note: I looked at Meraki documentation but I didn't find an answer.
It's probably a Meraki issue. I suggest you open a support case.
khalidbochajra
Just browsing
Thank you for your suggestion, I'll give it some time since it's just a demo but if it continues I'll definitely consider contacting Meraki support.
I've seen this before when you have config related to the network.  It's a bit vague in my mind now.
Check to ensure that no NATs are configured in that network.  Make sure AutoVPN is disabled.  Delete/disable any DHCP config.
