DHCP enabled WAN IP Conflict?
Jmbuan10
Hi All, I was wondering if this is an issue with Meraki MX. See screenshot below.
WAN 1 and WAN 2 was given the same IP Address by the router modems of both ISP. The WAN 1 failed. There are no event logs that says there is a conflict. We also confirmed that the router modems have internet connections. Any recommendation?
2 REPLIES 2
dont know the answer. but i would try set wan1 ip static to .3 and see what happens.
If this is two different ISPs then change the subnet being used by one of them to something different.  Otherwise you'll be in a world of pain.
