Integrating MX with Catalyst Switches in stackwise-virtual mode
rsage_voda
Anyone got any experience of mixing Meraki MX with catalyst switches in stackwise-virtual mode. Test Client working fine with access to the internet. When simulate a network failure by switching of the active switch the client loses connectivity to the internet and a continuous ping show an outage of circa 30 seconds. As a test re-established the network connectivity and just unplugged the connection from active C9407 to the Active MX P25 and still seeing loss of connectivity of up to 4 seconds.
Meraki MX does NOT support LACP for WAN or LAN ports. That means on the Catalyst side you must not use channel-group on the MX-facing ports.
If the Catalyst uplinks are in a port-channel, a failover will break traffic until the LACP state machine times out.
rsage_voda
Thank you for the response. The uplinks are not in a port-channel.
What would be the expected failover time?
Where are the ping packets lost?
How long did stp on port 2/1/0/5 take to get to forwarding state?
Brash
Yep. Sounds to me like STP convergence time. Logs on the switch should be able to confirm that.
