MX in Gov Cloud
TCBsos
MX in Gov Cloud
Fo the GovCloud this matrix says no subscription allowed (co-term only).
Do I only need the LIC-MX68-ENT-1YR then?
If I pick subscription instead of classic, the MX Small Essentials allows 36 months or greater.
Mloraditch
The LIC-MX68-ENT-1YR would provide a basic level of functionality for 1 year, whether you need that or advanced security, only you/your customer can say. You should be able to select longer terms as well.
I suggest you take a look at this article for descriptions of what is and isn't available in GovCloud:https://documentation.meraki.com/Platform_Management/Cisco_Meraki_for_Government/Cisco_Meraki_for_Go...
Regardless I would be talking to your Meraki Rep. Government requirements are complicated and different between Federal, state, etc and the government reps and SEs are trained for helping with these items.
TCBsos
Yes probably best to engage with a rep. Thanks
CarolineS
Meraki Alumni (Retired)
@TCBsos - Thanks for posting! I'm not certain if those prices you posted are meant to be public, so I am removing that part of your screenshot from your post. Cheers!
RobertHicks
D’après ce que tu dis, si la matrice pour GovCloud indique « no subscription allowed (co-term only) », cela signifie effectivement que tu ne peux pas prendre une simple souscription mais que tu devras opter pour une option co-terminée. En ce qui concerne le instantcasino-fr.app LIC-MX68-ENT-1YR, ça semble suffisant si tu veux une licence d’un an. Si tu choisis l'option abonnement au lieu de « classique », le MX Small Essentials qui permet 36 mois ou plus pourrait être une solution si tu souhaites une licence plus longue. Dans tous les cas, assure-toi que cela correspond aux exigences spécifiques de ton environnement GovCloud.
