adding extra info in API posts.
NeilB
I'm looking to add some new VLANs using the API and the main aspects work fine, however some variables appear to not be working successfully.
# ------------------------VARIABLES-----------------------------
# (1) Insert desired Network ID here from list above.
$networkid = $Test_Site
# (2) Insert New Management Subnet
$MGNTRANGE = "10.1.2.0/24"
# (3) Insert New DATA Subnet
$DATARANGE = "10.2.2.0/24"
# (4) Insert New VOICE Subnet
$VOIPRANGE = "10.3.2.0/24"
#----Formatting-----
$MGNTRANGESPLIT = $MGNTRANGE.split('.')
$MGNTRANGEIP = "$($MGNTRANGESPLIT[0]).$($MGNTRANGESPLIT[1]).$($MGNTRANGESPLIT[2]).1"
$DATARANGESPLIT = $DATARANGE.split('.')
$DATARANGEIP = "$($DATARANGESPLIT[0]).$($DATARANGESPLIT[1]).$($DATARANGESPLIT[2])"
$VOIPRANGESPLIT = $VOIPRANGE.split('.')
$VOIPRANGEIP = "$($VOIPRANGESPLIT[0]).$($VOIPRANGESPLIT[1]).$($VOIPRANGESPLIT[2])"
#Array of rules required to be pushed to network as defined above. All fields are required.
$data = @{
            id="3000"
            networkId="$networkid"
            name="BLEUGH"
            applianceIp="$DATARANGEIP.1"
            subnet="$DATARANGE"
            dnsNameservers="upstream_dns"
            dhcpHandling="Run a DHCP server"
            dhcpLeaseTime="1 hour"
            dhcpOptions=
                        "code"=43
                        "type"=text
                        "value"="<DHCP OPTION INFORMATION>"
#Convert arrays above to JSON format.
$json = $data | ConvertTo-Json -Depth 4;
Write-Host $json
This is written in powershell as i am using the Invoke-RestMethod call to Post this data, however the additional hashtable for dhcpOptions heading doesn't show in the dashboard, but shows correctly in the JSON output that is sent (See below). Also the dhcpLeaseTime value doesn't appear to change either if i enter "1 week" or "1 hour", it just appears to default to "1 day".
"subnet": "10.2.2.0/24",
"dnsNameservers": "upstream_dns",
"name": "BLEUGH",
"dhcpHandling": "Run a DHCP server",
"applianceIp": "10.2.2.1",
"id": "3000",
"dhcpLeaseTime": "1 hour",
"networkId": "<NETWORK ID>",
"dhcpOptions": [
"value": "<DHCP OPTION INFORMATION>",
"code": "43",
"type": "text"
Any help gratefully appreciated,
Cheers
Neil
2 Replies 2
Edgar-VO
Hey,
This is something in Python
my_lijst = []
my_lijst.append(eval("{'type': 'text', 'code': '15', 'value': 'company.com'}"))
param['dhcpOptions'] = my_lijst
response = dashboard.vlans.updateNetworkVlan(network_id,def_vlan_id,**param)
this is cause dhcpOptions should be an array..
Usually i do create a VLAN/Site what i want with the GUI, then i export the JSON using the API....That information i will use as as a template
@Edgar-VO wrote:
Hey,
my_lijst = []
this is cause dhcpOptions should be an array.. five nights at freddy's
Thanks, I give it a go to figure it out.
