New MS 14.10 firmware, finally addresses the too early upgrade of MS120s
Switch firmware versions MS 14.10 changelog
Alerts
MS390 stacks of 4 or more may experience instability on this release. For stacks of 4 or more please stay on the current general release to ensure stability and functionality.
MS390 upgrades from MS 14.9 or earlier will trigger a full system reload
MS390 client authentication may fail closed if RADIUS server passes unsupported AVPs
Auth session state on RADIUS server may be stale following an MS390 CoA update until RADIUS Accounting is supported
MS210/225/250 switches cannot forward IPv6 Router Advertisement and Neighbor Solicitation packets when flood unknown multicast is disabled (has always been true)
Bug fixes
MS425 stacks directly exposed to large L2 domains can experience stability reduction
Client and traffic analytics data may be inaccurate for traffic traversing MS390-series switches
MS120, MS355 and MS450 series switches can reboot too quickly during firmware upgrades, interfering with timely upgrades of other switches
MAC forwarding table live tool does not return data for MS390 series switches
Known issues
Non-MS390 switch stacks using Dynamic ARP Inspection can block ARP packets which should actually be permitted
MS390 stack members may not report client-level detail
MS390 series switches Max MTU is limited to 9198 bytes
MS390 series switches will not display packet details in the DHCP Servers page
MS390 series switches do not support the 'next-server' or 'bootfile' parameters in DHCP messages
Rebooting a single switch in an MS390 stack will reboot the entire stack
LLDP frames from MS390 series switches will use a single system name instead of the Dashboard given name
MS390 series switches will not display the advertising router ID for OSPF
MS390 series switches with OSPF enabled will default to an IP MTU of 1500 bytes on every OSPF enabled interface
MS390 series switches do not support the multicast routing livetool
MS390 series switches do not support tagged traffic bypass for voice on ports with a Multi-Auth access policy
Dynamic VLAN assignment from a RADIUS server on MS390 series switches must already be an allowed VLAN on the port for it to function
MS390 series switches do not currently support the following features: VRRP, SM Sentry, Syslog server, SNMP, Traceroute, IPv6 connectivity to dashboard, Meraki Auth, URL Redirection, MAC Whitelisting, RADIUS Accounting, Loop Detection, UDLD, MAC Flap Detection
SM Sentry does not support Windows based clients (predates MS 10.x)
MS425 series switches do not forward frames larger than 9416 bytes (predates MS 10.x)
MS350-24X and MS355 series switches do not negotiate UPoE over LLDP correctly (predates MS 10.x)
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
LITHIUM.Form.resetFieldForFocusFound();
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5ed50819cf0ebe","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5ed50819cf0ebe_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5ed50819cf0ebe_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_5ed50819cf0ebe_2","feedbackSelector":".InfoMessage"});
LITHIUM.AjaxFeedback(".lia-inline-ajax-feedback", "LITHIUM:hideAjaxFeedback", ".lia-inline-ajax-feedback-persist");
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_5ed50819cf0ebe","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
