I read with excitement the post by @Nikitha about Meraki Insights integration with ThosuandEyes. But I've found the first bug already. 🙂
I'm from New Zealand, and I can just see an outage bubble, but it's not possible to scroll far enough to make it display on the map.
Hello PhillipDAuth
Thank you for using this feature. Is the bug that you can scroll the page to see the bubble or would you like to Zoom in further to get to a specific region in New Zealand?
The bug is that it is not possible to be able to get NZ on the map. You can see from my screenshot I had the scroll bars to the max and could not bring up New Zealand on the visible map.
How did you manage to do it?
I was able to get NZ on the map on Chrome 99 with my mouse wheel :
same. works fine here in mac os chrome and firefox on multiple devices.
Although I really think it's a pity that New Zealand is not directly visible on that map: same here, I can simply scroll in and push the map around a little bit.
