Client VPN not connecting-Bad Technical Support
D2Flores
We are asking for an update on when can this be fixed. We are losing millions at the moment since most of our are people working from home because of the pandemic. I was able to contact the Support team after an hour of waiting and he just hangs up on me. 😡😠
4 REPLIES 4
Inderdeep
@D2Flores : Tough time, understand you pain. Follow-up is there on the below tread. They found the issue and fix is on the way. Waiting for the ETA.
https://community.meraki.com/t5/Dashboard-Administration/Hosted-Services-Issues/m-p/125510
Regards/Inder
www.thenetworkdna.com
Inderdeep
@D2Flores : Can you check if issue resolves ?
Regards/Inder
sdunant
Finally, Client VPN is working.
Inderdeep
@sdunant : ok thts good !
Regards/Inder
