We have a layer 3 non meraki gateway on our LAN network on the range 10.232.86.0/26 as well as our main subnet 192.168.6.0/24
The gateway address is 10.232.86.1 and our server address for this range is 10.232.86.22
We need to connect a laptop remotely into our network via Client VPN so that it is in the same range / can ping these two address. Basically when the device connects it needs to be able to send network traffic through this gateway.
The ClientVPN range used was 172.40.100.0/24 however there are no routes to the 10.232.86.0/26 range in the route table. I also used the 10.232.86.0/26 range for our Client VPN but still no routes in routing table.
I can't ping this range or IP 10.232.86.1 from our MX appliance
I setup a second MX appliance (on a second broadband link) on the same LAN yesterday. I put the mx ip on the same range as 10.232.86.0/26 and I could ping the gateway 10.232.86.1 from the appliance. However when I connected to the Client VPN 172.40.100.0/24 it didn't know how to talk to 10.232.86.1 or any ip addresses in the range. I couldn’t put the Client VPN range on the 10.232.86.0/26 range as it was already used for the mx appliance ip.
Currently devices on the LAN are dual ip addressed on windows so they have a 192.168.6.0 range as well as a secondary ip on the nic with 10.232.86.0/26 range with static routes on windows to direct the traffic for the 10.232.86.0/26 range out the gateway 10.232.86.1
So basically the switch is doing all the layer 2 work and everything knows to go to the correct gateways.
Can anyone please advise and provide some guidance?
Also note: We don’t have control of this 10.232.86.1 router so any time we need a route added we need to log a call with the ISP.
