The MR Installation Guides have instructions for mounting. Pick the appropriate guide for the AP you are planning to install. The mounting plate for the MR I have in my test set-up even has a built in spirit level to assist accurate placement.
If you check here, you will see that the mounting plates have templates that may be used for any required drilling
