Guest WiFi
BBDave
Guest WiFi
We are just moving over to Meraki MR33 and the cloud dashboard.
We currently have a Cisco Wireless Controller and Cisco AP's where we create the Guest accounts.  We currently have a Guest WiFi which is Vlans off to a separate DSL line via the controller.
We would like to do the same on the Meraki Dashboard but allow guests to create their own accounts.
Is there anyway of doing this without a MX appliance?
Dave
1 REPLY 1
kYutobi
You can set up self registration if you use the option "Merkaki Authentication" in Access Control of Wifi.
