Group Policy Equipment needed?
wseyller
New to the Meraki products.
I found that I can apply layer 7 policies.   For example prevent a wireless client from using Netflix.
If I only have a meraki access point are these Group policy available for use.  Considering if I used some other non Meraki firewall and switch equipment.
Or do this policy feature work off a MX security appliance?  Can these policies work when the only Meraki devices in use are the access points.
Also can these policies be applied per client if using a built in Meraki client list or does it apply to only an SSID, or either?
AjitKumar
Hi
I believe you are considering only Meraki Access Point.
Layer 7 policies are included with Meraki Access Point License. You do not require a Meraki firewall for this to work.
The L7 policies can be applied to entire SSID or you may create a Group Policy and apply to specific end user device too.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
thanks for the info.  I had a hard time finding the clarification on that.
https://documentation.meraki.com/MR/Group_Policies_and_Blacklisting/Creating_and_Applying_Group_Poli...
